NiHo_202842
10 years agoWill auto policy builder handle wildcards parameters like PAR1, PAR2, PAR3 -> PAR?
Hello,
I am currently building up a policy in manual mode. Due to the size of this application, it requires a fair bit of work to add all parameters to the policy. A lot of these parameters are in ...
Erik_Novak
Employee
10 years agoYes--but there is one important condition that must be met: If you are using automatic policy builder, and you would like to ASM to learn each unique parameter, you must select Comprehensive mode (as the policy type) when you build the policy in the Deployment Wizard. This will ensure that the learning method for parameters is Add All Entities. If you've already got a policy, you can still change the learning method for parameters to Add All Entities yourself.
