James_Waldrop_8's avatar
James_Waldrop_8
Sep 17, 2009
Width/size of values?
What width data type are LocalLBPool statistics stored in? I'm getting this from test code:
| STATISTIC_SERVER_SIDE_BYTES_IN : 1922215810
| STATISTIC_SERVER_SIDE_BYTES_OUT : -1151353991
| STATISTIC_SERVER_SIDE_PACKETS_IN : 1374173472
| STATISTIC_SERVER_SIDE_PACKETS_OUT : -1836436750
This seems likely to be an overflow error, but I wanted to confirm.
TIA,
James
  • icontrol returns 32-bit high and low numbers, which you'll need to convert to a 64-bit number.
    Powershell courtesy of Joe:
     function Convert-To64Bit(){
       param($high, $low);
       $low = [Convert]::ToString($low,2).PadLeft(32,'0')
       if($low.length -eq "64")    {
           $low = $low.substring(32,32)
       return [Convert]::ToUint64([Convert]::ToString($high,2).PadLeft(32,'0')+$low,2);
    In python, you can see in this function to get wide IP statistics the same math:
     def get_wideip_stats(obj):
             try:
                     stats = obj.get_all_statistics()['return']
             except:
                     "Unable to fetch wideip list or get statistics - check trace log"
             for x in stats['statistics']:
                     print "WideIP: ", x['wide_ip']
                     print "\n"*2
                     for y in x['statistics']:
                         value = y.get('value')
                         high = value.get('high')
                         low = value.get('low')
                         value64 = (high<<32)|low
                         print "\t", y.get('type') , value64
    HTH...Jason
  • Does anyone have sample code for the Java version of this? Java's lack of unsigned long is making me grumpy.
    James
  • Search the forums for java 64-bit if this doesn't help you, as there at least a few examples
    long myresult_low = (long)(commonstat[5].getValue().getLow());
    long myresult_high= (long)(commonstat[5].getValue().getHigh());
    long myresult = (long)(commonstat[5].getValue().getHigh()<<32)+(long)(myresult_low);
  • It is a 64 bit unsigned number: http://devcentral.f5.com/wiki/default.aspx/iControl/Common__ULong64.html
    Here's an article Don wrote on using the method in Java:
    http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=78 Click here
