why is the Quota Management not apply in PEM F5 static subscriber
Hello
I trying to activate quata manamnet for a static subscriber in BIG iP PEM
the policy is working , but the quota is not assigned
Here is a screenshot from a test user called AMIR
root@(F5_LDN2)(cfg-sync Standalone)(Active)(/Common)(tmos)# show pem sessiondb subscriber-id AMIR
Pem::Sessiondb
Blade number 0
TMM number 5
Subscriber Information
Subscriber Id AMIR
Subscriber Id Type Private
Subscriber Type Static
Session Information
IP Address 192.168.232.100%1
Policy Server Session Id
Quota Server Session Id
Session State provisioned
Session Origin static subscriber database
User-Name
3GPP-IMSI
3GPP-IMEISV
3GPP-User-Location-Info
3GPP-RAT-Type
Called-Station-Id
Calling-Station-Id
NAS-IP-Address
NAS-IPv6-Address
Device Name
Device OS
Bytes Uplink 24449
Bytes Downlink 15558
Flows Total 148
Flows Current 0
Flows Max 2
Transactions 0
Policy Name Policy Type
Need urgent assitance please
Amir
- AubreyKingF5Ret. Employee
Hey, Amir. Did you follow a guide for the setup? Like this one:
https://techdocs.f5.com/kb/en-us/products/big-ip-pem/manuals/product/pem-implementations-13-0-0/5.htmlJust checking. Also, can you list that instead of show for me?
- amiros
Altocumulus
hello
Thank you for responding
the issue is that she subscriber comes from another external system
the only isdenttification that i have is an IP address
can i used the quota managemnt as with only IP addreess as the login subscriber ?
Amir
Maybe we should back up. What are you trying to accomplish? Are you trying to rate limit an IP? Typically, quota is derived from a query to a diameter resource or such.
- amiros
Altocumulus
Hello Aubrey
i am trying to do a rate limit based on an IP address
is it possible?
Amir
