Why inband monitor has been created as other monitor like HTTP do check particular webpage content available or not.
inband monitor mark pool down when client request did get the response from particular pool member in particular period of time. HTTP monitor will check for the content from backend server on that basis it will mark pool member down or up. ?
Why inband monitor has been introduced and Is there any material where I will get more about monitor function in the background for each type?
Inband monitor is sort of passive monitor and it become active when there is some traffic request to the VIP. This way, you are able to save bandwidth. In contrast, others are active monitor - whether there is any traffic to VIP or not, F5 will perform healthcheck as per defined frequency.
- Panki_308017
in which scenario and condition we should use inband monitor ?
- Faruk_AYDIN
Altostratus
for example, your company subscribes some services, and your boss want you to load balance and monitor them, on the other hand all the service providers want money each request whichever is, if you write a monitor for those services, this means that extra money. In that situation, you can use passive(inband) not to be any extra charge for monitoring.
