Which method of load balancing is appropriate in my case.
Which method of load balancing is perfect in my case.
I have 3 servers (A,B,C) I want to make...
A= As an active server, and responsible for all current connection.
B= Once A goes down then B became Active automatically
C= Once A and B both goes down then C become active automatically.
Is this possible with load balancing method or I have to use irule.
Thanks a lot, in advance for your help.
- Andy_McGrath
Cumulonimbus
Priority Groups.
Enable within the pool by setting the
to be Less than 1Priority Group ActivationSetup three priority groups within your pool, assign server A to the highest value say 30, B to the middle value say 20 and C to the lowest value say 10, that should do it.
