johnbernardcheu's avatar
Oct 01, 2017
What's the diff between Match Across Virtual Servers and Match Across Pools?
Hi there, i m looking at this link: https://support.f5.com/csp/article/K5837. And I still don't get the difference between Match Across Virtual Servers and Match Across Pools. Don't they both end up pointing to the same node? Can someone help me understand? Thanks!
  • The behaviour is quite different:
    Match across services ensures that a client that has a connection via one port to a pool member will connect to that same pool member with a new connection on a different port.
    client --> https virtual --> pool member 1
    client --> http virtual --> pool member 1 match across services
    Match across pools is used on a virtual that may direct content to multiple pools based on a policy/irule. The persistence record matches on the client ip address and sends to the pool and member regardless of the irule:
    client --> http virtual "/url1" --> pool_1
    client --> http virtual "/url2" --> pool_2
    client1 --> http virtual "/url1" --> pool_1 node 1
    client2 --> http virtual "/url2" --> pool_2 node 1
    client1 --> http virtual "/url2" --> pool_1 node 1 match across pools
    client2 --> http virtual "/url1" --> pool_2 node 1 match across pools
    I hope this is clear.
