Sajan_Mania_381
Altostratus
Jan 23, 2019What is the command to test http Monitor with GET and recv string ?
How can we test/confirm the services on the back-end server if below Monitor is applied on the VIP .
ltm monitor http http_Check { adaptive disabled defaults-from http destination : interval 5 ip-dscp 0 recv GOOD recv-disable none send "GET /CheckSys/CheckSys.aspx" time-until-up 0 timeout 16
Regards ,
Sajan
- Andy_McGrath
Cumulonimbus
You can use
command from the bash shell to confirm the response from each pool member e.g.curlcurl -v http:///CheckSys/CheckSys.aspx
