What client language/toolkits are you using for iControl development?
Hi everyone, I was just wondering what client languages/toolkits you all are using for building your iControl apps. Here's my main list in order of the frequency I use them.
- PowerShell -> iControl Cmdlets
- C/.Net -> iControl Assembly
- Perl -> SOAP::Lite
- Java -> iControl Library for Java (Apache Axis based)
Take a second if you would and reply to this thread and let's see how big a list we can come up with.
-Joe
- Steve_Brown_882Historic F5 AccountMost of the scripts have done real work with have been written in python as I decided to learn python when I started playing with iControl. That said I have also played with done a very little with Perl and Powershell as well.
Python -> pycontrol v2
Python -> pycontrol v1
Perl -> SOAP::Lite
Powershell -> iControl Cmdlets - JRahm
Admin
- Python -> pycontrol v2
- Powershell ->iControl.dll
- JT_106685
I'm using C as I many of my users are admins and I don't want to embed credentials into a clear text language. - L4L7_53191
Joe: do I really need to even answer this one :) - Lee_Payne_53457
I use c mainly because I give our developers access and they need to bulk enable and disable pool members (each server is a member of 10+ pools) - Hamish
Cirrocumulus
Perl. SOAP::Lite
I've also played with iControl via Objective-C. But it's just not as easy as perl (With perl there's so many more clever people contributing code that you can re-use).
H - Steffen_Beach_8
C -> iControl Assembly
Powershell -> cmdlets && -> iControl when I need something not in a cmdlet.
Ex:
(Get-F5.iControl).ManagementPartition.set_active_partition($partitionname)
(Get-F5.iControl).SystemFailover.get_failover_state() - adurstewitz_188
Java -> iControl Library for Java (Apache Axis based) - George_Watkins_Historic F5 AccountRuby -> iControl library :-)
- Chris_15024
Testing out using the native JAVA API inside Jython versus pyControl. It is a little cleaner and less stuff needs to be loaded into the jython installation, plus we still get to use Python syntax to fit in with an existing solution. Been working like a charm.
Would love to hear feedback on this particular usage scenario, good or bad.
