WEB Application Firewall Installation Questionnaire
Hello
Is there any questionnaire for WAF Installation? I need to give that to my customer to fill and after that optimize and confiugure the WAF?
Thank you
- LeonardoF5_1747
Yes ,
First you should know THE FOLLOWING:
Type of Operating System (Windows , Unix, etc. ) Type of Web Server (Apache , ISS, etc ) Type the application language (PHP , ASP.NET , XML, LOTUS , etc. ) Type of application Database ( MySql , Oracle , Sybase , IBM DB2, etc )
All this to quit false negatives on your policy ASM.
With this data you can know that use Positive security model or negative.
Regards.
- Amir_Mehri_1608
Thank you dear LeonardoKYf5
Is there any Document or questionnaire that can i download and use that? How about the other parameters like http/https connection per sec and etc. i need a sample questionnaire form to configure the ASM.
Thank you A.Mehri
