MikeWaisbrot_65
Feb 11, 2011Web Accelerator
New to F5 and this environment.
Question: Can someone help me verify whether or not web accelerator is running on the following platform 3400 with 9.4.3
On the 3400 is the web accelerator different from the compression and ssl addons to ltm?
b platform output
PLATFORM INFORMATION --
| Marketing Name: BIG-IP 3400
| BIOS Rev: AMIBIOS(C)2002 American Megatrends, Inc. BIOS Date: 02/21/
05 15:21:14 Ver: 08.00.06 OBJ-0075-01 REV A.
| base MAC: 00:01:D7:5F:EC:80
| PVA Version: 2
+-> SYSTEM INFO
| Type: C62a
| Chassis serial: bip228203s Level 200 part: 200-0255-05 REV B
| Switch board serial: PCA0100MSEB0 part: PCA-0100-02 REV A
| Host board serial: TY7BU12A0037 part: MOB-0013-03 REV A
| Annunciator board serial: 0702CF050727 part: OEM-0029-06 REV B
| Memory: 2.047GB
+-> HARDWARE CARDS
| | Type: compress Model: Cavium NITROX
| | version: CN1000-MC-Main-SSL-0.99a
+-> CPU 0
| | Type: Intel(R) Pentium(R) 4 CPU 2.80GHz Speed: 2799.320MHz
| | Temp: 38degC Fan speed: 10887rpm
+-> CHASSIS TEMPERATURE
| | (101) 31degC (102) 26degC (1) 33degC
+-> CHASSIS FAN
| | (101) active (102) active (103) active (104) active
| | (105) active (106) active
+-> POWER SUPPLY
| | (101) active
+-> LICENSE ADD LTM MODULE add ons
| | ADD 5 MBPS COMPRESSION
| | ADD SSL 100
+-> LICENSE ADD RAMCACHE add ons
- Chris_Miller
Altostratus
WA is indeed different than the built-in RAMCACHE, SSL, and Compression LTM license. - brianokelly_119
Hi Mike,
You should see the following when WA is installed:
+-> LICENSE BIG-LTM-8900 add ons
| | Local Traffic Manager Module
| | ADD IPV6 GATEWAY
| | ADD RATE SHAPING
| | ADD RAMCACHE
| | 50 MBPS COMPRESSION
| | SSL 500 TPS Per Core
| | ADD SSL CMP
| | ADD ANTI-VIRUS CHECKS
| | ADD BASE ENDPOINT SECURITY CHECKS
| | ADD FIREWALL CHECKS
| | ADD NETWORK ACCESS
| | ADD SECURE VIRTUAL KEYBOARD
| | ADD WEB APP
| | ADD MACHINE CERTIFICATE CHECKS
| | ADD PROTECTED WORKSPACE
+-> LICENSE WebAccelerator, 8900 Bundle add ons
| | WebAccelerator Module
| | ADD 500 MBPS COMPRESSION
| | Maximum Compression
| | ADD SSL MAX TPS
