we have 3 external web urls which will come on our frontend f5 and redirect to internal web urls and use as a revers proxy
should redirect to
how we can make iRule so it should work
- Kevin_Stewart
Employee
It's interesting how often this comes up, and the most important thing to understand here is the (potentially incorrect) use of the term "redirect". In HTTP-speak, and equally in BIG-IP iRules, a redirect is a flow control command. Given a typical reverse proxy configuration, where a client request flows through the proxy to the server, a redirect inserted at the proxy causes a preempt response back to client without passing traffic to the server. I'm assuming that's not what you want.
So based on your description, there are at least three requirements:
- Terminate the client side SSL and pass server side HTTP unencrypted
- Parse HTTP requests
- Modify the HTTP Host request header
The first is accomplished by incorporating a client SSL profile. The second is accomplished via attached HTTP profile. And the third can be a fairly straight forward iRule. I'm assuming here that all three external URLs are coming to the same virtual server and iRule.
when HTTP_REQUEST { switch [string to lower [HTTP::host]] { "site1ex.com" { HTTP::host "site1in.com" } "site2ex.com" { HTTP::host "site2in.com" } "site3ex.com" { HTTP::host "site3in.com" } default { HTT::host "site1in.com" } } } - raj_Kumar_19166
Thanks Kevin for your responses.
indeed, its looks same requirements. I will be incorporating a client SSL profile suppose if i will use port 443 on VIP still HTTP profile required?
i am using only single public IP to VIP for all three web urls.
Kevin could you please explain why you used default {HTT::host "site1in.com" } at the end.
i hope it should be work my requirement is looks same, i will apply and update you.
appreciating your effort.
- Kevin_Stewart
Employee
Yes, you'll still need and HTTP profile on the VIP to be able to use the above iRule.
It was a guess. It's always good to include a "default" condition in a switch, so I guessed at what you'd want if the host name didn't match any of the previous tests.
- John_Alam_45640Historic F5 Account
Kevin meant
HTTP::host "site1in.com"not
HTT::host "site1in.com" - raj_Kumar_19166
Hello, Kevin good afternoon.
I have prepared iRule below, could you please verify will work or not?
when HTTP_REQUEST { if {[string tolower [HTTP::host]] equals "site1ex.com"} { HTTP::redirect "http://site1in.com" }
elseif {[string tolower [HTTP::host]] equals "site2ex.com"} { HTTP::redirect "http://site2in.com" } elseif { [string tolower [HTTP::host]] equals "site3ex.com"} { HTTP::redirect "http://site3in.com" } }i am not sure but i hope it should also work as its if condition only.
Hi Raj_Kumar,
it will work, but I would recommend to change the syntax slightly, so that you execute the
formating just once per[string tolower]
to save some CPU cycles...HTTP_REQUESTwhen HTTP_REQUEST { set low_host [string tolower [HTTP::host]] if { $low_host equals "site1ex.com" } then { HTTP::redirect "http://site1in.com" } elseif { $low_host equals "site2ex.com" } then { HTTP::redirect "http://site2in.com" } elseif { $low_host equals "site3ex.com" } then { HTTP::redirect "http://site3in.com" } }Cheers, Kai
- Kevin_Stewart
Employee
You may also want to add an else condition, unless you're certain that all requests will contain one of these three host names.
- raj_Kumar_19166
no no no Kevin all request will not contain one of these three host names. I just asked about the else rule that is this correct or not might be I am wrong. the hostname is defined, which will redirect to whom like below.
https://site1Ex.com --> http://site1in.com https://site2Ex.com --> http://site2in.com https://site3Ex.com --> http://site3in.com
request should be like above. and all external web URLs (https://site1ex.com .....) will use a common Virtual server.
and all internal web urls having below IP address site1in.com-> 10.10.10.1, site2in.com ->10.10.10.2, site3in.com ->10.10.10.3
then where we will assign these ip address ? so external traffic will goto internal web urls. how it will deside? is need pool member or not?
- raj_Kumar_19166
Hi Ray_Kumar,
I belive you don't want the request for https://site1Ex.com to become just HTTP redirected to isn't it?
Is the scenario you're trying to achive a classical reverse proxy setup, where...
- The external client would request https://site1ex.com
- The external client would hit your F5
- The F5 has to rewrite the HTTP host name from site1ex.com to site1in.com
- The F5 has to forward the request to 10.10.10.1:443 using site1in.com as host name
- The F5 has to forward the responses back to your client, while replacing any hints of site1in.com to site1ex.com
Cheers, Kai
