tshilidzi_66258's avatar
tshilidzi_66258
Sep 23, 2009
WCCP on Cisco 3750 Switch with Wanjet 500
I am experiencing a problem with a WCCP config between a Wanjet 500 and a cisco 3750 switch. There is a wanjet 300 on a remote site. There is full connectivity between the WJ. When everything is configured I am able to optimize traffic in only one direction. I have a server farm hanging off a VLAN on the 3750. The remote Wan Jet is inline on the site but i want to configure WCCP to work between my 3750 switch and the WJ. The WJ config is correct but the 3750 config is a little bit troublesome.How can i get the Traffic to be optimized in both direction?
Here is my config on the switch
VLAN 11:Server VLAn
Vlan 17:Wanjet vlan
Wan Jet IP address: 192.168.230.10 255.255.255.0
ip wccp 99 group-list 15
int vlan 11
ip address 192.168.220.1 255.255.255.0
ip wccp 99 redirect in
access-list 15 permit 192.168.230.10
  • macwilliams_566's avatar
    macwilliams_566
    Historic F5 Account
    The Cisco 3750 switch needs to have SDM configured in order to redirect packets to the WANjet. Also, the 3750's only support L2 and assignement = mask. See below for a working configuration.
    Here is a sample Cisco config:
    sdm prefer routing << you need to save and reboot the router after this.
    [...] << also notice that it does not show on the output of 'sh run'
    ip routing
    ip wccp 51
    interface GigabitEthernet5/0/2
    switchport access vlan 5
    switchport mode access
    interface Vlan1
    ip address 172.30.13.247 255.255.255.0
    interface Vlan5
    ip address 10.102.0.254 255.255.255.0
    ip wccp 51 redirect in
    interface Vlan10
    ip address 10.102.1.2 255.255.255.0
    And the WANjet 500 config:
    b wccp list all
    wccp server-wccp {
    cache timeout 10
    services 51 {
    priority 10
    protocol tcp
    port type none
    traffic assign mask
    hash fields srcip
    weight 50
    redirection l2
    return l2
    tunnel local addr 10.102.1.201
    password none
    egress method negotiated
    routers 10.102.1.2
    port none
    tunnel remote addr 172.30.13.247
