Stan_Ward_01_13's avatar
Stan_Ward_01_13
Oct 26, 2015
warning: [use curly braces to avoid double substitution]
I'm getting this a lot while converting irules from v10.2.4 to v11.5.3, and I don't understand either the warning or the fix.
Here are a few random (unrelated) lines with the warning:
  • if [catch {virtual name} virtualName]
  • set aclmr_virtualSite [lindex $aclmr_parts [expr [llength $aclmr_parts] - 2]]
  • if [catch "matchclass $aclmr_clientIP equals $aclmr_ipLookupClass" val] {
  • set lWay [expr $lWay - 1]
  • set virtualSite [lindex $parts [expr [llength $parts] - 2]]
What is the general situation that the warning is about, and how should it be corrected? I've seen comments that you should just add another layer of {} around expressions, but that has sometimes generated bad values at runtime (where the original lines, with warnings, work fine). Other answers I've seen posted just said "change xxx to yyy and it will work" without explanation.
  • Discdog_230929's avatar
    Discdog_230929
    Historic F5 Account
    1) An understanding of double substitution is necessary to avoid injection attacks. Tcl parses a command, performs substitutions on the words of the command, and then executes the command. Some commands in turn perform additional processing of the arguments they receive. eval, subst, and various other commands interpret their arguments as a script to be executed, and pass the script back to Tcl for another round of evaluation. expr, if, and while parse their arguments according to the grammar of expr, resulting in another round of variable and command substitution. Double substitution refers to the substitution that happens during these additional rounds of interpretation. Double substitution can be useful, but is more often the result of inadvertently neglecting to brace the arguments to expr or to the expr arguments of if and while. static syntax analysis tools can be used to locate these occurrences in a script. KBK: Braced expressions on if, while, and expr aren't just safer, they're also much, much faster. Unbraced ones have to be parsed at run time; braced ones can be compiled down to very tight bytecode sequences.
    expr In expr scripts, $ causes variable substitution and [ causes command substitution.
    Arguments to expr should almost always be braced because it avoids the first layer of substitution by the Tcl interpreter. The same is true for the first argument to if and while. This is mentioned on the Tcl Style Guide page and is discussed a bit on A Question of Style.
    2) So the warnings are put in place to suggest you work them out.
    3) So rewriting them stops the possibility of an injection attack so the warning will no longer appear when rewritten. (In the F5 error or warning statement is a suggested way of correcting the problem also.)
    4) For a more thorough explanation see: double substitution http://wiki.tcl.tk/1535
