Vxlan tunneling bewteen two F5
Good moring to all.
In a test environment i'm trying to test VXLAN tunneling between two f5 and QinQ support.
I got 2 GUEST running on 11.6 with 3 vlan QinQ configured: - vlanS2000C200 (simulate a bare metal end-point A) Configured in GUESTA - vlanS2001C201 (simulate a bere metal end-point B) Configured in GUESTB - vlanS2002C202 (simulate a wan connection where i build the vlan tunne) Configured in both GUESTA and B
GuestA is deployed in ViprionA GuestB in ViprionB Both Viprions si connected to a Cisco ARS. To simulate the end-points, in the ASR i've configured 2 (BVI_A an BVI_B l3 interface) in vlanS2000C200 and vlanS2001C201 using the respective S tag an Ctag for L2 QinQ transport to the viprion I've also configured a igmp local querier in the ASR in the vlan vlanS2002C202 (where vxlan is builted)
I'm try to ping BVI_A form BVI_B and viceversa passing through F5 and using vlan group to bridge the vlans to the vxlan tunnel. So the packet path shoud be: ASR-S2000C200[payload]->F5-S2000C200[payload]->bridgeGuestA>VXLAN[payload]->bridgeGuestB->F5-2001C201[payload]->ARS2001C201[payload]
The problem is that nothing works. I see packets coming from the ASR to the interface vlanS2000C200 and i see the same packets to the vlan group interface BrigdeA but no packets in the vxlan tunnel and no packets in the vlanS2002C202 where the vxlan should be builted.
Any advice? PS: i do not see any IGMP query form the ASR..... so i've tryed to use vxlan with profile no-flow but nothing changed
M.G.
- Hebex_35785
Hi Mgullia, i have the sample problem, did you find a solution ?
