JimW_156953's avatar
JimW_156953
Mar 19, 2019
vs to front-end bigiq active device
Interesting problem: Commissioned bigiq devices - HA pair, therefore one is active and another standby.
The organization needs to create a simpler CNAME for huge team to access bigiq device with a CNAME i.e. f5management.example.com
Therefore i created a virtual server and attached both bigiq devices as nodes, assign ssl cert etc. all good.
PROBLEM: the virtual server in this case has no idea which device is active - the health monitors are simply checking http.
Question: What do I need to create a custom monitor which can only pass to the ACTIVE bigiq?
Thanks,
  • Hi
    Have you tired querying the api from a http monitor and then parsing the response - /mgmt/shared/failover-state for instance?
