python bigsuds - Connect to Active Device
Problem this snippet solves:
Connects to the active member of a Device Group regardless of the original hostname. Can be used as a function or as a command-line call.
How to use this snippet:
bigip-active.py <hostname> <username>
Script will prompt for password.
Code :
#!/usr/bin/env python # # bigip_active: Connects to the active member of a Device Group regardless of # the original hostname. __author__ = 'buzzsurfr' __version__ = '0.1' # Standard Library import sys import itertools # Related Third-Party import getpass # Local Application/Library Specific import bigsuds def bigip_active(hostname, username='admin', password='admin', debug=False, cachedir=None, verify=False, timeout=90): # Connect to specified BIG-IP b = bigsuds.BIGIP(hostname, username, password, debug, cachedir, verify, timeout) # Determine whether device is active if(b.Management.DeviceGroup.get_failover_status()['status'] != 'ACTIVE'): local_device = b.Management.Device.get_local_device() new_device = False for device in list(set(itertools.chain.from_iterable(b.Management.DeviceGroup.get_device(b.Management.DeviceGroup.get_list())))).remove(local_device): if(b.Management.Device.get_failover_state(device) == 'HA_STATE_ACTIVE'): new_device = device if(new_device): print b.Management.Device.get_local_device()[8:]+" is not active. Switching to "+new_device[8:] b = bigsuds.BIGIP(new_device[8:], username, password, debug, cachedir, verify, timeout) return b if __name__ == '__main__': bigip_active(sys.argv[1], sys.argv[2], getpass.getpass())
Tested this on version:
11.5Updated Jun 05, 2023
Version 2.0Theo_12742
Cirrus
Joined November 19, 2012
