VPN users disconnected but sessions still running
Hi All, I have very small quarry. when VPN user connected, we can see sessions from Access policy->ManageSessions. But when users disconnects from the VPN access, sessions are still running. Could you suggest from GUI where can i change the settings to resolve this issue. Your help will be appreciated.
- Arnaud_Lemaire
Employee
Hi, it depends the way they disconnect from the session : - if they just kill the client, or close the browser the session is still running until the inectivity timeout defined in the access policy configuration menu (access policy/access profile, select you access policy) - if they are using a web application accessed through a webtop you can use in the same menu the logout uri to logout the apm session when they logout from the application.
