Jim_M's avatar
Jim_M
Icon for Cirrus rankCirrus
Jun 20, 2019
VMWare/VDI blast protocol and LTM 12.X
I am using the VDI iApp successfully under BigIP LTM 12.2. I'd like to use the 'blast' protocol for VDI but i havent found any documentation on how to do it. Is a guide available?
  • To support proxying the Blast protocol you will need F5 APM and it is only supported using TCP (UDP support added in v14.0).
    If you just forwarding using LTM then it is just a standard TCP or UDP Virtual Server but need a VDI access profile to take full advantage to the protocol in APM.
