John_Ogle_45372
Jul 18, 2013vmware workstation 8 and two ve instances
I know my config isn't officially supported but I wanted to discuss it anyway, besides it isn't always feasible or easy to use ESX on a laptop.
if I load a single be ltm instance, everything is fine. When I load two ve instances, one of them always becomes corrupt. It has trouble loading, mcp doesn't respond and sometimes the eval license becomes invalid. Anyone else seen this?
thank you,
- Kevin_Stewart
Employee
How are you setting them up? Have you changed the default mgmt IP of the first before starting the other? - John_Ogle_45372
Yes. I configure each just like I am doing a real install. I just used the setup wizard for.these. I don't even use the 192.168.145.x network for management. I use a Nat interface for my external vlan so it can hit the internet and a Host interface for the HA network. I will dig into some more but its been quite frustrating. Also, I don't use ovf converter tool. I just double click on the file and let workstation perform its import process.
