bsdpruegelknabe
May 23, 2011VirtualServer::set_connection_mirror_state doesnt work since
Hello,
today I stumbled upon a strange error. Every time I call VirtualServer::set_connection_mirror_state it sets the mirror connection to true. Even if I set, with the API-call, it to disable!
This is what i see in the log files:
debug iControlPortal.cgi[16315]: LocalLB:+++++++++++++++++++++++++++++++++++++
debug iControlPortal.cgi[16315]: LocalLB:VirtualServer::set_connection_mirror_state ( ) called by user "admin"
debug iControlPortal.cgi[16315]: LocalLB: Virtual servers:
debug iControlPortal.cgi[16315]: LocalLB: [0] vs_mirrortest, State: Disable
debug iControlPortal.cgi[16315]: LocalLB:-------------------------------------
So, mirror connections should be disabled, right? But, if I look at the VS at the webfrontend (or with the API-call "get_connection_mirror_state") it is enabled! :-o
This change happend after upgrade to V10.X.X
Can anyone acknowlege this error? Does a workaround/bugfix exists?
Greetings,
bsdpruegelknabe
- I just tested this on my dev build of v11 and it behaves the same way, but then again my system isn't setup in a redundant configuration so that may effect the setting. Since the trace shows the correct parameters in and you aren't getting the desired result, this is likely a case to get product support involved as it looks like the is an issue with the backend implementation of this method.
-Joe - samstep
Cirrocumulus
This bug was reported previously:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/51/aft/1177001/showtab/groupforums/Default.aspx - bsdpruegelknabe
Ah, thank you both for confirmation. So I'm not just to dumb to use the API. ;-)
I hope they fix this with an hotfix also and not just with a new Release. :-)
Greetings,
bsdpruegelknabe
