Viprion v2400 blade migration from 2100 to 2250
Hi Team, we have viprion 2400 with slot 1 : blade 2100. As this blade is going to be EOL, we are deciding to go for B2250 in slot 2. We are using HA and will do the changes one by one. There is no VCMP config.
Have seen the migration script on f5 portal: https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/viprion-blade-migration, example:2.
However, having below question. 1. Will both 2100 and 2250 blade support during migration on viprion 2400? 2.after script, needs to use 10Gb interfaces using QSPF 40Gb converter cable: so the config saved on new blade during migration needs to change for interfaces and reassign the vlan again? 3. Please advice if Any unknown issues, advice.
