mikegray_198028
Cirrus
May 08, 2017viprion help
Can we upgrade all guest vcmp at time from host device ?
- nathe
Cirrocumulus
mike, you can do but the recommendation is if two guests share a slot then you should do them individually, and not at the same time. See the following solution and, in particular, the upgrade considerations section: Overview of vCMP configuration considerations
Hope this helps,
N
