viprion help
Hello Team,
we are using Vipiron 2400 pair in HA and we have 4+ vcmp guests. if i fail-over the active Host, will it fail-over all vcmp guest also?
- Samir_Jha_52506
Noctilucent
if i fail-over the active guest, will it fail-over all vcmp guest also?No. Only individual guest will failover, where you will perform failover action. Rest other vcmp guest will be same like previous stage.
Sorry Jhaas, I was asking about viprion host to host failover . if I failover viprion host A to host b, will it failover all the guest LBs in the host A to the LBs in the host B
- fgf_165674
Hello,
Depends on where the guests are active, if they are active on host A or host B.
If some guest is active on host A, this guest will fail-over when the host A fail-over to host B.
But if the guest is active on host B, this guest will NOT fail-over when the host A fail-over to host B.
The Host can be active on chassis A but the Guest can be active on chassis B.
Regards,
