VE on KVM (OpenStack on RHEL) Hard Disk Drive Allocation Issue
Hi all,
I'm having an issue when installing VE (Only LTM provisioned, TMOS v11.4.1) within OpenStack, which is using KVM running on RHEL. Instead of getting around 20Gb allocated per volume, I'm only getting around 5Gb which makes it impossible to upgrade or even install hotfixes.
I've not experienced issues with VE/LTM as per this: https://devcentral.f5.com/questions/big-ip-ltm-ve-on-kvm so it shouldn't be a cause, the right data existed already. Odd to note that I had to implement this 'hack' for BIG-IQ but the disk volume allocations are correct.
Thanks in advance.
- What_Lies_Bene1
Here the output from DF; ~ df -h | grep -v none Filesystem Size Used Avail Use% Mounted on /dev/mapper/vg--db--hda-set.1.root 380M 192M 169M 54% / /dev/mapper/vg--db--hda-set.1._config 504M 71M 408M 15% /config /dev/mapper/vg--db--hda-set.1._usr 2.2G 1.7G 404M 81% /usr /dev/mapper/vg--db--hda-set.1._var 1008M 329M 629M 35% /var /dev/mapper/vg--db--hda-dat.share.1 504M 231M 248M 49% /shared /dev/mapper/vg--db--hda-dat.log.1 1008M 666M 292M 70% /var/log prompt 4.0M 28K 4.0M 1% /var/prompt - What_Lies_Bene1
Also, getting no output from [tmsh] show sys disk - What_Lies_Bene1
FYI I'm running v11.4.1 which requires KVM running on RHEL 6.3. v6.4 (which I'm using) is not supported.
