VE 11.2.0 final and vmware_view_5.2012_08_23 | Error telling me to add more than one Server Pool Member
When I run through the iApp, it tells me I need to add more than one Server Pool Member when there are 5 added.
Any suggestions?
Thanks,
Ben
- Fred_Slater_856Historic F5 Account
I haven't seen that problem, but perhaps the first thing to do is download the latest View template. https://devcentral.f5.com/wiki/iApp.VMware-View-iApp-v1-0-0.ashx
-Fred
- ben_wyatt_12961Historic F5 AccountHi, Thanks Fred - I was informed that this was the latest one: https://clouddocs.f5.com/api/iapps/VMware-View-5-iApp-Template.html I presume that is not the case - would you be able to confirm how you know yours is definitely the latest. Thanks again. Really appreciate it. KR, Ben
- Fred_Slater_856Historic F5 AccountWe're maintaining an iApp codeshare page now, which has application-specific pages with both code and deployment guides, including one for View. https://clouddocs.f5.com/api/iapps/CodeShare.html We have also adopted a numeric release suffix to replace the dated-based suffix (for example, .v1.0.0 instead of .2012_08_23).
- ben_wyatt_12961Historic F5 AccountHi Fred - thanks again. Can you confirm this template is not F5 verified? If not - I don't suppose you know why ....?
vmware_view.v1.0.0rc3 is not F5-verified. It is a candidate for that status, but it must pass our regression tests. In general, this is more work than building the template in the first place. We release the candidate templates to DevCentral beforehand so customers have early access to a template that is identical or very close to what will be the official release. Note that all "Community-contributed" and most "F5-contributed" templates on DevCentral are NOT candidates for the F5-verified status and will not go through this testing.
