F5_349259's avatar
F5_349259
Apr 09, 2018
vcmp guest shutdown before chassis upgarde
Hi all,
i am planning to upgrade viprion chassis to new version.Before upgrade i think we have to manually shutdown vcmp guests(configured state) and then make them up(deployed state) once chassis get booted with new code.My question is when we shut down the guests and then make them up post chassis upgarde will the running configuration be there on guests by default ?
  • Surgeon's avatar
    Surgeon
    Ret. Employee
    I am not sure if I understand correctly. Guests config files do not located on host. They are located on virtual disks. Virtual disks partition is shared across boot locations.
    After vcmp host upgrade, the config on the guests should remain.
