Variables in SSH CLI? Help automating backups
I'm looking for a better way to speed up backups. I have looked into some of the custom scripts and iApps, but all seem a little messy, so I just do them manually. Even if I can speed them up a little bit and come up with a one-size-fits-all command I can run that would work for now. I don't know anything about Bash, Cron, etc. just trying to do something simple that works.
Here is what I am doing on each of my devices:
tmsh save /sys ucs /var/local/ucs/HOSTNAME-DATE.ucs
scp -p /var/local/ucs/HOSTNAME-DATE.ucs USERNAME@FTPSERVER:/home/DIRECTORY/
Obviously I have to update the HOSTNAME and DATE manually each time. Can anyone help me with a way to automate this, where HOSTNAME and DATE are automatic, so I can just paste a simple set of commands into each device?
- JG
Cumulonimbus
scp -p /var/local/ucs/${HOSTNAME}_$(date +%G%m%d_%H%M) USERNAME@FTPSERVER:/home/DIRECTORY/ - jaikumar_f5
Noctilucent
Can help you with a simple bash script provided you have a jump server which can reach all your remote F5 servers.
If SSH keys have been exchanged(Passwordless login), the work is more simpler. If not we can go with a simple sshpass to through pwd.
Let me know if you have jump server and key exchanged.
