Dan_Whipp_25399
Jul 09, 2007v9 to v4 conversion: partial re-encryption
Trying to determine if this v9 iRule to do a partial re-encryption of traffic based on URI can be converted to v4.
rule login-reencrypt {
set reencrypt 1
if {[HTTP::uri] contains "Login.fcc"} {
pool https-pool
set reencrypt 0
pool http-pool
when SERVER_CONNECTED {
if { $reencrypt == 0 }{
SSL::disable
- hoolio
If you hadn't figured this out yet, you should be able to handle the server side SSL in the pool configuration. You could then use a rule to set the pool based on the URI.
Aaron
