Alscion_68122's avatar
Alscion_68122
Dec 01, 2011
v11 & Volume management
Hi all,
How can I create a new Volume in v11 or v11.1? In the section System > Disk Management, I can delete Volume or db already created but I don't see how to Create a new volume.
Any Idea?
Thanks.
  • volume is not needed to be created before installing. it can be done in one shot.
    root@ve1100(Active)(/Common)(tmos) show sys software
    Sys::Software Status
    Volume  Product  Version   Build  Active    Status
    HD1.1    BIG-IP   11.0.0  8037.0      no  complete
    HD1.2    BIG-IP   11.0.0  8131.0     yes  complete
    HD1.3      none     none    none      no  complete
    root@ve1100(Active)(/Common)(tmos) install sys software hotfix Hotfix-BIGIP-11.0.0-8131.0-HF1.iso volume HD1.4 create-volume
    HD1.4    BIG-IP   11.0.0  8037.0      no  installing 0.000 pct
  • Yes, via cli you can create the volume at the installation but via the GUI, you have to select an existing Volume, how can I create a new Volume before launch the installation?
  • but via the GUI, you have to select an existing Volumecan't you type volume set name? i am running 11.0.0 hf1 and am able to type e.g. 5 when installing.
  • Posted By Alscion on 12/02/2011 12:47 AM
    In Version 11.1.0 you can type a name of a new volume or choose from the drop down box.
    So, if you want to create a volume name HD1.4, type the number 4 in the selection field.
    Hope that helps.
  • I replaced a blade on a VIPRION 2400 VCMP 16 (RMA) and two vCMP came with orginal volumes while two did not. They only had one volume so I could not do the upgrade.
    Here is what I found to work.
    from the command line (tm shell)
    (/Common)(tmos) install sys software image BIGIP-11.3.0.2806.0.iso volume HD1.2 create-volume
    You can also boot.
    then I installed the hotfix ei:
    install sys software hotfix Hotfix-BIGIP-11.3.0-3022.0-HF3.iso volume HD1.2
