Hans_Schneider2's avatar
Hans_Schneider2
Jul 23, 2013
UTF8 Encoding Problem
Hello,
I need to add some string to a payload that is in UTF8 encoding.
When I am using any command after HTTP::collect - all the characters displayed wrong.
I found a topic about this, that suggest to use a STREAM profile.
But I am not allowed to change virtual server configuration so I cannot use it.
Is it another solution?
Thanks.
  • A couple of observations:
    1. There are generally TWO ways to alter HTTP payloads: STREAM and HTTP::collect/payload. Once you've collected all of the required payload, you can use any manner of string manipulation or regex to manipulate the data. A STREAM profile is *almost* as flexible, but will usually run much faster than the other option.
    2. You can use an iRule to manipulate a STREAM profile, and only add a generic (blank) STREAM profile to the virtual server configuration.
    3. Both HTTP::collect/payload and a STREAM profile/iRule are going to work with string data. If you're having UTF8 issues with one, you'll likely have the same problem with the other.
    4. Whether adding a STREAM profile or an iRule, you're modifying the virtual server configuration regardless.
    Can you please elaborate on the UTF8 issue?
  • You are right.
    But when I checked it using Stream the problem did not occured. The issue is I am not allowed to use Stream, only an irule, so i have to use
    Http::collect method.
    The payload in UTF8 (it is the charset defined in the header of Http request), that i have to change with the irule, contains characters that are not English.
    In http::collect method when I am using some replace method or simply add in the end of the payload another string - all the characters in the page not represented correctly anymore (each character corrupted in some way).
    And a cannot convert the string that i am adding to payload into UTF8 since "encoding" tcl command is disabled in F5 irules.
  • So just to be clear, the STREAM method is still an iRule. You just need a blank STREAM profile applied to the VIP, the same way you need an HTTP profile applied to the VIP to use HTTP commands in an iRule. Take a look at the STREAM::expression wiki page for examples:
    https://devcentral.f5.com/wiki/iRules.STREAM__expression.ashx
    Otherwise, can you share your current iRule and specific string examples?
