Using wildcard for multiple URI
We have an existing iRule and datagroup,
set uri [HTTP::uri]
if {[class match $uri starts_with DG1]} {
pool POOL_SSL
if {[class match $uri eq DG_EXACT] or $uri eq "/" } {
pool POOL_SSL
Is it possible to use a wildcard like "/*" in the datagroup such that we no longer need to add thousands of URI in the future?
- jaikumar_f5
Noctilucent
If your intention is to allow every URI of a particular domain, why do you put wildcard of /* rather than just whitelisting the particular domain itself.
So you need not worry of adding thousands of URI, but just allow that particular host.
when HTTP_REQUEST { if { [HTTP::host] contains "domain.com" } { pool POOL_SSL } else { drop } } - stan_piron
Cumulonimbus
When reading your code, you can see there are 2 Datagroups
- DG1 with command starts_with which does the same as you expect
- DG_EXACT with command equals
So the code seems good!
- stan_piron
Cumulonimbus
This code may replace all irules!
when HTTP_REQUEST { set uri [HTTP::uri] set target [getfield [HTTP::uri] "/" 2] if {[class match $uri starts_with DG2]} { pool POOL_OTHER1 } else { switch -glob -- [HTTP::uri] { "*/other2*" - "/other2_1*" - "/other2_1*" { pool POOL_OTHER2 } "/other3*" - "/other3_1*" - "/other3_2*" - "/" { pool POOL_OTHER3 } "/other3_3*" { pool POOL_OTHER3_3 } "/3_4*"{ pool POOL_OTHER3_4 } "/3_5/" { pool POOL_OTHER3_5 } "/3_6/" { pool POOL_OTHER3_6 } default { pool POOL_SSL } } } } when SERVER_CONNECTED { if { [LB::server pool] eq "POOL_OTHER2" } { SSL::disable serverside } }
