Using source address affinity persistence, but exluding certain IP addresses
I would like to use source address affinity persistence, except for a few known IP addresses for which I do not want to use any session persistence at all (for stress testing the cluster, etc).
Can I configure this without having to re-implement source address affinity persistence with an iRule?
- nathe
Cirrocumulus
Daniel,
If you didn't want iRules, and you were on TMOS v11.3 or above, then I can only think of two virtual servers (same ip:port combination) and then configure the Source Address bit of the VS config. On the one you can apply src add persistence and configure a Src Address of Any (perhaps) and on the other one you don't have persistence and choose a narrow Src Address in the VS config to only match these IP addresses.
Hope this helps,
N
- cshannahan_3137
I'm in the same boat but I'm not familar with irules. I have a pool with source persistance turned on. Unfortunately we have added 2 more servers to this pool but they aren't getting used because the hosts hitting them only have 2 servers. I would like to LB across all 4. Is there a way to turn off source persistance just for 2 incoming connections? If I have to create a new vip/pool I guess I could but it will require a lot of fw changes.
