Shahrzad_84598's avatar
Shahrzad_84598
Feb 27, 2016
Solved
Using one BIG-IP LTM chassis on two separated security network layers
Hi there!
I need to know if I can use one BIG-IP chassis to run load balancing on web servers(Layer1) and Database servers(Layer2) at the same time... I mean from security point of view, is it possible to connect one BIG-IP Interface to Web access-switch and another BIG-IP Interface to Database access-switch or we should buy two BIG-IP chassis? (Of course We have a firewall between Web & DB Servers)
Thanks Shahrzad
