Chris_Phillips's avatar
Chris_Phillips
Jan 13, 2012
using iRule name within rule
HI,
Is there any way to find the name of the irule being executed within the rule, as per [virtual name] for the virtual service? I want a simple way to pick up a data group with a specific name based on the name of the irule. I've tried using [virtual name] but it feels messy an unreliable depending on the way you assign rules etc.
This is the only thing I need to make a rule I'm working on totally generic and not need any customization at all between different copies of the same rule (which is how this place works...). Currently I have a "set static::prefix website_abc" etc, in the RULE_INIT. I know this is "trivial" to change, but it'd be really helpful if I can keep the contents of the rule byte for byte identical as it'd allow easier versioning change management etc.
Chris
  • hoolio's avatar
    hoolio
    Hi Chris,
    I don't think there is a native way to get the name of an iRule. But I remember seeing a request for enhancement for this. You could open a case with F5 Support to get your request added to the RFE.
    Aaron
  • I may well, although I've a feeling I'll decide life's too short after all!
