Using iFiles with iRules - Updating Problem
I’ve run into an issue that I cannot seem to find an answer to, so, I’m hoping someone can point me into the right direction.
Basically, I have an iRule that checks if there’s at least 1 active member in my pool. If there’s not at least 1 active member in the pool, the iRule will put up a maintenance page; that maintenance page is an iFile called MaintPage (just a basic html page).
My problem is that if I make a change to the iFile, that update will not register/refresh and continue to use the old version. My workaround has been to edit to the iFile and then remove it from the list (Local Traffic>>iRules : iFile List>>MaintPage) and then add it back in order for it to update. Hope that makes sense…
Here is the iRule for reference:
switch [HTTP::host] {
"sub.domain.com" {
if { [active_members my-pool] < 1 } {
HTTP::respond 200 content [ifile get MaintPage]
pool my-pool
Thanks again for looking,
Zac
Thanks, I was able to figure this out.
Before, I was using vi to edit the file in "/config/filestore/files_d/Common_d/ifile_d/MaintPage.html" and after I made the update, the page wouldn't reflect the update.
Now, I go into tmsh and enter "edit sys file ifile MaintPage.html" and after I make the changes, the page is updated.
Thanks!
- nitass
Employee
My problem is that if I make a change to the iFile, that update will not register/refresh and continue to use the old version.how did you modify the file?
This is my testing.
create text file [root@ve11a:Active:Changes Pending] config cat /var/tmp/simpletext.txt this is original simple text. root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) create sys file ifile simpletext_file source-path file:/var/tmp/simpletext.txt Copying file "file:/var/tmp/simpletext.txt" ... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 30 0 30 0 0 65502 0 --:--:-- --:--:-- --:--:-- 0 root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list sys file ifile simpletext_file sys file ifile simpletext_file { checksum SHA1:30:0c34c01d448d15874f45477a8ba8e699a196325b create-time 2013-07-11:15:16:28 created-by root last-update-time 2013-07-11:15:16:28 mode 33152 revision 1 size 30 source-path file:/var/tmp/simpletext.txt updated-by root } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) create ltm ifile simpletext_ifile file-name simpletext_file root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm ifile simpletext_ifile ltm ifile simpletext_ifile { file-name simpletext_file } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar ltm virtual bar { destination 172.28.20.111:80 ip-protocol tcp mask 255.255.255.255 profiles { http { } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vlans-disabled } root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule qux ltm rule qux { when HTTP_REQUEST { HTTP::respond 200 content [ifile get simpletext_ifile] } } [root@ve11a:Active:Changes Pending] config curl http://172.28.20.111 this is original simple text. modify the text file [root@ve11a:Active:Changes Pending] config cat /var/tmp/simpletext.txt this is new simple text. root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) modify sys file ifile simpletext_file source-path file:/var/tmp/simpletext.txt Copying file "file:/var/tmp/simpletext.txt" ... % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 25 0 25 0 0 39308 0 --:--:-- --:--:-- --:--:-- 0 [root@ve11a:Active:Changes Pending] config curl http://172.28.20.111 this is new simple text. - zblue_123071
Altocumulus
Thanks!
