Brian_Barnes_84's avatar
Brian_Barnes_84
Aug 06, 2008
Using ASN library with iRules
Hello,
I am new to using iRules. I was able to write a rule and test it with a command line tcl interperator. However I am not able to get it installed. I am wondering the correct way to call the ASN library. Here is what I have. I need to use the asn::asnGetSequence etc.
Here is my iRule
when SERVER_DATA {
      Grab the current payload collected
     set payload [TCP::payload]
 set pdu $payload
 For testing in command line mode.  This is a sample data packet.
 set pdu "\x30\x82\x03\x9f\x02\x01\x02\x64\x82\x03\x98\x04\x39\x63\x6e\x3d\x65\x63\x73\x55\x6e\x69\x78\x41\x64\x6d\x69\x6e\x73\x2c\x6f\x75\x3d\x47\x6c\x6f\x62\x61\x6c\x2c\x6f\x75\x3d\x55\x6e\x69\x78\x50\x72\x6f\x76\x2c\x6f\x75\x3d\x53\x45\x52\x56\x49\x43\x45\x53\x2c\x6f\x3d\x48\x43\x53\x43\x30\x82\x03\x59\x30\x82\x03\x55\x04\x09\x6d\x65\x6d\x62\x65\x72\x55\x69\x64\x31\x82\x03\x46\x04\x19\x63\x6e\x3d\x41\x32\x35\x38\x39\x38\x35\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x35\x39\x34\x30\x33\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x1a\x63\x6e\x3d\x41\x44\x4d\x32\x39\x39\x36\x35\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x46\x44\x32\x36\x31\x38\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x33\x35\x31\x31\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x33\x37\x39\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x34\x39\x33\x32\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x35\x38\x36\x34\x33\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x35\x39\x32\x37\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x33\x38\x36\x30\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x55\x31\x33\x37\x34\x39\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x34\x31\x38\x35\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x34\x36\x30\x34\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x34\x39\x39\x39\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x35\x36\x39\x35\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x32\x34\x35\x30\x43\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x39\x35\x32\x32\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x36\x32\x30\x35\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x38\x38\x34\x36\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x30\x37\x34\x33\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x36\x35\x30\x36\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x38\x37\x39\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x36\x30\x38\x33\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x38\x38\x30\x31\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x34\x31\x30\x31\x43\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x37\x30\x34\x30\x37\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x37\x30\x35\x36\x39\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x37\x30\x36\x33\x38\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x36\x38\x39\x31\x37\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x49\x32\x37\x31\x33\x34\x36\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x04\x19\x63\x6e\x3d\x41\x32\x36\x33\x35\x39\x31\x2c\x6f\x75\x3d\x45\x4d\x50\x4c\x2c\x6f\x3d\x48\x43\x53\x43\x30\x0c\x02\x01\x02\x65\x07\x0a\x01\x00\x04\x00\x04\x00"
 log local0. "Orig PDU ASCII:  $pdu"
 binary scan $pdu H*c hexPDU Lenth;
 log local0. "Orig PDU Hex:  $hexPDU"
      The first byte is the tag signifying an BER message type, (sequence of constructed data)
      Always is hex 30, if that is not so reject
 binary scan $pdu H2c berT berLength
 log local0. "BERT: $berT"
     if { $berT ne "30" } {
   TODO:  verify exit command.
   If not sequence, ignore.  Check if this is the right command to exit the rule.
         return
 Strip the type and length from the pdu
 asn::asnGetSequence pdu searchEntry
 log local0. "Untagged searchEntry:  $searchEntry"
 Get the messageID.
 asn::asnGetInteger searchEntry messageID
 log local0. "My messageID: $messageID"
 Check for search response; exit iRule if not reponse
 asn::asnGetApplication searchEntry appNum
 log local0. "appnum: $appNum"
 if {$appNum == 4} {
 Get the DN of the object being returned in the search.
 asn::asnGetOctetString searchEntry matchedDN
 log local0. "My matchedDN: $matchedDN"
 If the object is not in the UnixProv container; exit iRule
 if {[string match *$unixBase $matchedDN]} {
 asn::asnGetSequence searchEntry attributes
 log local0. "Sequence of all Attributes: $attributes"
 loop through attributes, look for reformAttr, store attribute sequences in a list for re-assembly
 list to hold our attributes.
 set resultAttrs {}
 while {[string length $attributes] != 0} {
 asn::asnGetSequence attributes attr
 log local0. "Attribute Sequence: $attr"
 asn::asnGetOctetString attr searchAttrName
 log local0. "My attr: $searchAttrName"
 if we find the reformAttr loop through values and reformat packet
 else we leave the packet alone
 if {[string match $reformAttr $searchAttrName]} {
 asn::asnGetSet attr searchVals
 log local0. "my vals:  $searchVals"
 set cnVals {}
 while { [string length $searchVals] != 0 }  {
 asn::asnGetOctetString searchVals value
 log local0. "NextVal: $value"
 log local0. "length: [string length $searchVals]"
 regexp {[^cn=][a-zA-Z0-9]*} $value newValue
 lappend cnVals [asn::asnOctetString $newValue]
 set matchedAttr "1"
 log local0. "New values:  $cnVals"
 set attr [asn::asnOctetString $searchAttrName][asn::asnSetFromList $cnVals]
 put all the attrs in a list
 log local0. "attr: $attr"
 lappend resultAttrs [asn::asnSequence $attr]
 end loop through attributes
 if {$matchedAttr} {
 If refromAttr was found, repackage the attributes in a sequence
 set newSearchEntry [asn::asnInteger $messageID][asn::asnApplication $appNum [asn::asnOctetString $matchedDN][asn::asnSequenceFromList $resultAttrs]]
 log local0. "New search entry sequence:  $newSearchEntry"
 If response does not contain the reformAttr, exit without modifying the results
 log local0. "reformAttr not found."
 return
 If response is not in UnixProv container, exit without modifying the results
 log local0. "Not in the UnixProv container"
 return
 If not a search response, exit without modifying the results
 log local0. "Not a search response."
 return
 if we made it all the way through (and have new data to package) put the packet back together and send it on its way.
 if {$matchedAttr} {
 add search result databack into pdu
 set newData ""
 append newData $newSearchEntry
 append newData $pdu
 log local0. "My new pdu minus tag:  $newData"
 pack the final PDU; ready to ship
 set pduFinal [asn::asnSequence $newData]
 log local0. "Final PDU:  $pduFinal"
 Set the payload
   TODO:  This might need some work.
 set TCP::payload pduFinal
For the TCL command line interperator I used a couple lines at the top of the script to test the code:
package require Tcl 8.4
 package require asn 0.8.3
 namespace import ::asn::*
Thanks,
Brian
