opiekelly's avatar
opiekelly
1 year ago
Using AS3 for CSR(via Venafi), VIP, and GSLB
Hello All, I would like to automate requesting BIG-IQ to generate a CSR request via Venafi integration. Have the cert signed by Venafi.  Create a complete VIP setup with the certificate.  Create GSLB for this new VIP.  All via the AS3 interface.  I used chatgpt and it outputted the below steps and wondering if this is on the right track.
F5 BIG-IQ and Venafi Integration with GSLB Configuration - Complete Steps
Step 1: Generate CSR via F5 BIG-IQ API (with SAN)
In this step, we will generate a CSR (Certificate Signing Request) using F5 BIG-IQ’s API. This CSR will include SAN (Subject Alternative Names) as required.
API Call to Generate CSR:
POST https://big-iq.example.com/mgmt/cm/certificates/requests
Authorization: Bearer <f5_token>
Content-Type: application/json
  "command": "generate",
  "name": "exampleCertRequest",
  "commonName": "example.com",
  "keyType": "rsa",
  "keySize": 2048,
  "subjectAlternativeNames": [
    "www.example.com",
    "api.example.com"
  "organization": "ExampleOrg",
  "organizationalUnit": "IT",
  "country": "US",
  "locality": "San Francisco",
  "state": "CA"
Step 2: Submit CSR to Venafi via F5 BIG-IQ API
After generating the CSR, submit it to Venafi for signing using F5 BIG-IQ’s built-in Venafi integration.
API Call to Submit CSR via F5’s Venafi Integration:
POST https://big-iq.example.com/mgmt/cm/certificates/requests/<CSR-ID>/submit
  "caReference": "/mgmt/shared/venafi/venafi-instance",
  "requestType": "new",
  "zone": "exampleZone",
  "validityPeriod": "P1Y"
Step 3: Check Status of the Certificate Request
You can track the status of the certificate request to see when it is signed by Venafi.
API Call to Check CSR Status:
GET https://big-iq.example.com/mgmt/cm/certificates/requests/<CSR-ID>
Step 4: Retrieve the Signed Certificate
Once the certificate has been signed by Venafi, you can retrieve it using the following API.
API Call to Retrieve Signed Certificate:
GET https://big-iq.example.com/mgmt/cm/certificates/requests/<CSR-ID>/certificate
Step 5: Create the Entire VIP Configuration Using AS3
This combined AS3 declaration will define the full VIP configuration, including SSL, pool members, health monitors, and load balancing.
AS3 Declaration:
  "class": "ADC",
  "schemaVersion": "3.0.0",
  "id": "VIPWithSSL",
  "tenant": {
    "class": "Tenant",
    "application": {
      "class": "Application",
      "template": "generic",
      "myCert": {
        "class": "Certificate",
        "certificate": "/Common/signedCert.crt",
        "privateKey": "/Common/privateKey.key"
      "clientSSL": {
        "class": "SSL_Profile_Client",
        "certificates": [
            "certificate": "myCert"
      "myPool": {
        "class": "Pool",
        "monitors": [
            "use": "/Common/http"
        "members": [
            "serverAddresses": [
              "10.0.0.1"
            "servicePort": 80
              "10.0.0.2"
            "servicePort": 80
              "10.0.0.3"
            "servicePort": 80
        "loadBalancingMode": "least-connections-node"
      "myVIP": {
        "class": "Service_HTTP",
        "virtualAddresses": [
          "192.0.2.10"
        "virtualPort": 443,
        "pool": "myPool",
        "sslProfile": {
          "client": "clientSSL"
Step 6: Configure GSLB Pool Using AS3 (FQDN and Ratio Load Balancing)
This step sets up a GSLB pool using FQDN-based members and the ratio load balancing algorithm.
AS3 Declaration for GSLB Pool:
  "class": "GSLB_Pool",
  "members": [
      "server": "server1.example.com",
      "ratio": 5
      "server": "server2.example.com",
      "ratio": 3
  "loadBalancingMode": "ratio"
