Robert_Pagano_7's avatar
Robert_Pagano_7
18 years ago
Using a "remote" system to maintain up/down status of a VIP and/or pool members?
Is it possible to maintain the up/down status of a VIP (and/or its related pool/pool members) by querying a real server that is totally unrelated to the pool?
Specifically, let's say I have a VIP called "test-vip" which references a pool called "test-pool." The "test-pool" has, for example, two members: "test-pool-member1" and "test-pool-member2."
Normally, one would use some sort of health-check against the members of "test-pool" to determine if they are available.
Recently, however, I have been asked to configure the load balancer so that, instead of checking the pool members directly to determine if they are up/down, it should check for the existence of a file on a totally separate system (for example, a file named "system-is-in-maintenance-mode" on a server named "some-other-server"). If that file is present, the VIP should be unavailable.
This, as you might surmise, is intended to alert clients when the system is intentionally down for maintenance; so a fallback host will be configured to redirect clients to a "maintenance" page.
Would such an approach work?
Of course, other suggestions on how to do a "maintenance page" are welcome.
Thank you!
Rob
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Hi Rob --
    Could have sworn I already answered this one, sorry!
    Yes, you can do that by creating a custom monitor of type HTTP & specifying in the monitor definition:
    Send String. . . . . .GET /system-is-in-maintenance-mode.html
    Receive String . . . .
    Alias Address. . . . .
    Alias Service Port . .
    You might need to add HTTP version, Host & Connection headers as specified in this solution: https://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.html
    (Click here)
    HTH
    /deb
