Deb_Allen_18
May 24, 2006Historic F5 Account
Using a cookie for universal persistence
(This is a followup to this post: Click here)
I'm trying to use a cookie for universal persistence.
I can't seem to find any documentation that clearly describes how universal persistence rules should be constructed to work with cookies.
I gather that the general idea is:
1) there must be a response event in which the cookie value is extracted from the Set-Cookie header to create the persistence record;
and
2) there must be a request event in which the submitted cookie value is compared to the persistence table
However, this post: Click here and others seem to indicate that only the HTTP_RESPONSE portion is necessary to enforce persistence.
What am I missing?
/deb
tia for any light you can shed...
- Deb_Allen_18Historic F5 AccountThe final rule in this post: Click here worked, although as noted, there is still a critical outstanding question about how to extract the one Set-Cookie header you want to act upon.
/deb - JRahm
Admin
Deb,
Have you figured this one out? I have a customer asking for extracting only Set-Cookie information for logging purposes. Thanks.
