SynACk_128568's avatar
SynACk_128568
Mar 06, 2014
User able to telnet to VIP 80 but not 443 for same VIP
Hi All,
We are using http 80 to https 443 redirect . User is able to telnet to the port 80 but not port 443 . I took packet capture to see what is happening Connections are seen when telnet to VIP port 80 made . But not when user trying to telnet on port 443 . We have on VIP set up with ip protocol TCP rule is http2https which is fine. Profile fastl4 . Same set up on the 443 VIP . VIP status is available. Also this device is in DMZ so are 443 blocked in DMZ environment .
Any help will be appreciated.
  • Might it be possible that your telnet isn't able to negotiate an SSL session with the 443 VIP? If you run a tcpdump capture in front of the 443 VIP, do you see packets coming from the telnet client?
  • Hi Kevin,
    I took PC : tcpdump -ni any host CLient IP
    Client tried to telnet to VIP 443 using portquery . Any suggestions
    • SynACk_128568's avatar
      SynACk_128568
      Also when i telnet on the LTm itself to the VIP 443 . It is not connecting
  • So you're saying you do see traffic coming from the client to the 443 VIP? If yes, I'm assuming you see a complete 3-way TCP handshake and then it dies almost immediately after that?
  • No kevin i am not seeing any traffic coming to the VIP when user tries to telnet VIP 443 what is strange why i am not able to telnet to the port 443 there is also secondary VIP for same set up on different LTM but which i dont think is in DMZ . User is able to telnet it . I compared the Config everything is same except working has rule SNAT2VIP .
    Also can it be anything with portlockdown on the interface but for that LTM will send RST i guess.
