use port for inside access
I have an LTM that is in the DMZ only. Its whole purpose is to receive requests from outside to the DMZ then to the inside network. Is it possible to connect to the inside of my network from the available ports on the LTM so that interface can take advantage of the F5, but I do not want the outside requests to go to the inside directly, it has to go through the DMZ? Thanks.
- Eric_St__John
Employee
Short answer, yes, however there is likely a bit more work and reconfiguration that would be required. What you would need, at the very least, is Route Domains. You can ease some of the administration of placing objects into Route Domains by utilizing Administrative Partitions, and the "Default Route Domain" setting within that Administrative Partition.
Regards, Eric
