URL Restriction Best Way
I have hosted one URL for our company on F5 - xyz.com, due to security audits, i have been asked to allow only specific paths, like -
xyz.com/ucc/xyz/mnn xyz.com/abc/nuu/ooo xyz.com/abc/nuu/dsf xyz.com/abc/nuu/wer xyz.com/abc/nuu/sd xyz.com/abc/nuu/df
The list of path is big (around 20). What would be the best way to achieve it. I know it is possible by irule but it would be a big irule and may not be best approach.
Thanks in advance.
- Vijay_E
Cirrus
when HTTP_REQUEST { set URI [string tolower[HTTP::uri]] if { not ([class match $URI eq CLASS_ALLOWED_URI]) } { discard } }You would have to create a data-group and name it as CLASS_ALLOWED_URI (or anything else you want). The data-group will contain the list of allowed URI. The iRule uses reverse-logic and drops all requests that doesn't match the allowed URI list.
