Kate_Kattar_107
Jul 22, 2008URL forwarding help
I have a fairly simple request but need some guidance regarding the best way to do it. My client is lauching a new website and would like to forwarding 30 other urls to this new url. For instance:
www.site1.com should be forwarded to www.newsite.com/site1
www.site2.com should be forwarded to www.newsite.com/site2
Should I be using irules to do this?
What syntax should I use? Something like this:
if { [HTTP::host] equals {www.prioryhospital.com} and [HTTP::uri] equals "/"} {HTTP::redirect "http://bbc.co.uk"
return
This incidently doesn't work and I imagine its a little messy.
Cheers
Kate
- The_Bhattman
Hi Kate,
There are number of ways to do this. One that comes to mind is the switch command
I.Ewhen HTTP_REQUEST { switch -glob [HTTP::host] { "www.site1.com" { HTTP::redirect "http://www.newsite.com/site1" } "www.site2.com" { HTTP::redirect "http://www.newsite.com/site2" } "www.site3.com" { HTTP::redirect "http://www.newsite.com/site3" } "www.siteN.com" { HTTP::redirect "http://www.newsite.com/siteN" } . . . } }
Click here to find out more about the switch command
Hope this helps
CB - Kate_Kattar_107
Thank You. Works perfectly and its so simple.
Much appreciated. - Kate_Kattar_107
I have now been asked to make further additions to the rule. The following does not work. Do I need to use a different value other than [HTTP::host]?
"host.co.uk/about.cfm" { HTTP::redirect "http://www.newhost.co.uk/page1 " }
"host.co.uk/audit.cfm" { HTTP::redirect "http://www.newhost.co.uk/aboutpage " }
} - Andy_Herrman_22
HTTP::host only gives you the hostname (host.co.uk). HTTP::uri will give you the path (/about.cfm), so try:when HTTP_REQUEST { switch -glob "[HTTP::host][HTTP::uri]" { "host.co.uk/about.cfm" { HTTP::redirect "http://www.newhost.co.uk/page1 " } "host.co.uk/audit.cfm" { HTTP::redirect "http://www.newhost.co.uk/aboutpage " } } }
You might run into case issues though (if someone goes to host.co.uk/About.cfm it wouldn't be caught). In which case you'd want to do something like this:when HTTP_REQUEST { switch -glob [string tolower "[HTTP::host][HTTP::uri]"] { "host.co.uk/about.cfm" { HTTP::redirect "http://www.newhost.co.uk/page1 " } "host.co.uk/audit.cfm" { HTTP::redirect "http://www.newhost.co.uk/aboutpage " } } }
