zafer's avatar
zafer
Feb 05, 2010
uri based load balance
Hello
i'm using this iRule but i have problem.
The problem is when i request the url "www.domain.com/Touch" (it does not work) but if i add "/" at the end of the word it works (www.domain.com/Touch/)
i think web server is rewriting the url.The request change after the connect to the server www.domain.com/Touch/abc/index.jsp
i think if i add "/" after the word it will work, how can i do this or any suggestion
set uri_info [HTTP::uri]
if { $uri_info starts_with "/Touch" or $uri_info starts_with "/cis" } {
pool pool_9081
} elseif { $uri_info starts_with "/Dispatch" } {
pool pool_9085
} else { HTTP::redirect "https://[HTTP::host][HTTP::uri]"
  • Hi Zafer,
    The following example code simply examines the URI for a "/" and if it does not it performs a redirect with "/" at the end.
        if { [string tolower[HTTP::uri]] eq "/touch" } {
           HTTP::redirect "http://[HTTP::host]/[HTTP::uri]/"
    I hope this helps
    Bhattman
  • zafer's avatar
    zafer
    it redirects request it is not load balance to the specific pool or member
    zafer
  • Hi Zafer,
    I think I miss understood. Here is another rework of the code
    Here is an example
        set uri_info [strng tolower [HTTP::uri]]
        switch -glob $uri_info {
           "/touch" {
                    HTTP::redirect "https://[HTTP::host][HTTP::uri]/"
           "/touch/*" -
            /cis*" {
                    pool pool_9081
           "/Dispatch*"
                    pool pool_9085
    I hope this helps
    Bhattman
  • zafer's avatar
    zafer
    Hi
    in this implementation bigip will take webserver role from ibm server, load balance and redirect request to the specific pool
    my problem ;
    if client request type like this www.xx.com/touch (not works)
    www.xx.com/touch/ (it works)
    i worked with irule with these type solutions; append and rewrite url (append "/" and rewrite uri set uri $new_uri/) but i got another problems
    i use append "/" but irule append "/" in to the all url
    regarding rewrite url, "www.xxx.com/touch" rewrited to the "www.xxx.com/touch/" but after the login page bigip removes "/touch/" from url and we got some problems....
    i changed your irule with my requirements. is that solve my problems, can be loop problem redirection and load balance to the pool
    set uri_info [string tolower [HTTP::uri]]
    "/touch" {
    HTTP::redirect "http://[HTTP::host][HTTP::uri]/" -----> add / to the url then
    "/touch/*" {
    pool pool_9081 -------------- load balance the specific pool
    "/cis" {
    "/cis/*" {
    pool pool_9081
    "/Dispatch*"
    pool pool_9085
