f5now_28704
Oct 03, 2007URI and case sensitive
Hi all,
I just made a rule for to redirects and it works 100%. but Im not sure if I can make it so its not case sensitive? so it would also answer for /Desktop or /DeskTop
if { [HTTP::uri] eq "/desktop" } {
HTTP::redirect "http://www.google.com/Solutions/Desktop/tabid/122/Default.aspx"
if { [HTTP::uri] eq "/trial" } {
HTTP::redirect "http://www.google.com/Trial/tabid/121/Default.aspx"
thanks for any help.
- f5now_28704
Yah I had see that "string tolower" command but wasnt clear on its total use. I thought it was for moving from all upper case to lower case or at least that was the examples I had see posted.
anyways thanks again
Ryan - Colin_Walker_12Historic F5 AccountIt is for moving everything to lowercase.
By changing the string you're inspecting completely to lowercase before the comparison is made, you can ensure that case has no relevance in your comparison. Does that make sense? :D
Colin - f5now_28704
ok, now I get it. thanks for the explanation
Ryan - Colin_Walker_12Historic F5 AccountNo sweat, glad I could help. Let us know if you've got any more questions.
Colin
