Upgrade procedure from 11.5.0 TO 11.6.0 In active/standbye mode
Dears;
Please can you advice me for upgrade procedure ?
- nitass_89166
Noctilucent
isn't manual useful?
sol13845: Overview of supported BIG-IP upgrade paths and an upgrade planning reference
https://support.f5.com/kb/en-us/solutions/public/13000/800/sol13845.htmlManual: BIG-IP Systems: Upgrading Active-Standby Systems
https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-upgrade-active-standby-11-6-0.html- eng_mohamadawad
Thanks but why i shall re-activate f5 boxes , if manual reactivate is working or shall be automatic ? - eng_mohamadawad
i noticed that also 11.6 image is same image for devices is that right
- nitass
Employee
- eng_mohamadawad
- nitass
Employee
either is okay.
sol7727: License activation may be required prior to software upgrade for the BIG-IP or Enterprise Manager system
https://support.f5.com/kb/en-us/solutions/public/7000/700/sol7727.htmli noticed that also 11.6 image is same image for devices is that right
what do you mean?
- eng_mohamadawad
yes you are right , it is required ;) so we shall do it to be in safe side
- eng_mohamadawad
