fgf_165674
Jul 18, 2016Upgrade 11.5.1 --> 11.5.4
Hello,
I have upgraded a Viprion vCMP Host from 11.5.1 HF8 to 11.5.4 HF1.
After upgrade, the blade1 displays a state INOPERATIVE and the tmm proccess is restarting continuosly.
Do you know what can be the issue?
I have re-activate the license previous the upgrade.
Thanks.
I would:
- Contact support.
- Check the /var/log/ltm file to see if there's a specific reason for the TMM restarts
- Upload a qkview to ihealth to see if there's any known bugs
/Patrik
