san_239682
Jun 09, 2016Unknown-Shutdown state on a Slot for Viprion Device
We have observed one of the slot on our F5 Viprion device as blue square " Unknown(Enabled) -Shutdown : got signal 15 stopping".
Can anyone please help us to determine what was the problem with the slot and how to solve this issue.
Thanks in advance
- Vijay_E
Cirrus
Did you check the logs for errors ? Just enabling it should bring it back online, if there are no hardware errors.
Unknown could be because the blade is inoperative. Are the all slots unknown or just one slot/blade? Can you ssh into that bad slot and check its current state? ssh slotX Example: ssh slot1 If now, can you try to power off and power on that blade using a console or from the command line of working/running blade? bladectl -p 0 -b For example: bladectl -p 0 -b 1 <--- to off slot1 bladectl -p 1 -b 1 <--- to on slot1
