Narendra_26827's avatar
Narendra_26827
Jul 11, 2012
universal protocol persistence
We are having one iRule which is used to persist (Universal persistence) both http and websocket (ws, wss) protocols persistence.
switch -glob [string tolower [HTTP::uri]] {
"/api/channel*" {
pool "istumps2-chan-pool"
persist uie [HTTP::header "objectId"] 300
"/api/presence*" {
pool "istumps2-prsn-pool"
default {
pool "istumps2-nginx-pool"
persist none
Somehow for the above two (http & ws or wss) protocols the request are going to different nodes in the pool. For troubleshooting we had added the log statements in the above iRule to confirm this behaviour.
Is it possible that we can persist these connections both http and websockets to the same node in the pool.
Thanks in advance.
  • Richard__Harlan's avatar
    Richard__Harlan
    Historic F5 Account
    In the persist profile there are some check boxes about match across pools and match across services.You should be able to check match across pools and as long as the same members are in the pool it should send both requests to the same member.
