Universal Persistence not working as expected
Universal persistence is not routing traffic to the pool member whose(intended server) cookie is in the header?
I compared with working set-up and the only difference is Oneconnect profile is missing in the non working set-up
Could you please suggest ?
- Leonardo_Souza
Cirrocumulus
Can you provide part of your configuration? Virtual server and the iRule used for universal persistence?
You need to have an HTTP profile in the virtual server, to be able to process the cookies. You need oneconnect, or LB::detach, to make sure the load balancing decision is made in every Layer 7 request. Otherwise, 2 clients coming from the same connection (via a proxy for example), would go to the same backend server. This solution explains the problem:
https://support.f5.com/csp/article/K7964
